Activity Forums VEGAS Pro Multichannel audio capture in-sync with Video
  • Multichannel audio capture in-sync with Video
    Posted by Jeff Stroming on October 15, 2010 at 7:51 pm
    Hey!
    I am looking for a capture card that will let me capture a single video channel in sync with 5 or 6 audio channels. This is for a critiquing system, where I need to have the adjudicators comments recorded in separate audio channels underneath the video channel.
    I DO NOT want to have to sync up the audio after capture. What I have been doing is capturing the video through Vegas’s capture utility (and a Grass Valley ACEDVio card), and the multiple audio channels through a Delta 1010 audio capture card right off the timeline. However I cannot start both captures in sync with each other, and since I am capturing several hours at a time the two captures can be slightly out of sync by the end. Any ideas?
    Thanks for your help!
    Jeff Stroming replied 15 years, 10 months ago 2 Members · 2 Replies
  • John Rofrano
    October 16, 2010 at 3:06 am
    The only other way I can think of doing this is to have an external audio recorder genlocked to the camera. This would be very expensive and require a master clock for both units to genlock to (not to mention a camera and audio record that supports genlock). You may not WANT to sync the audio after the recording but it may be the only option you can AFFORD to do.
    I regularly sync 1-2 hr recordings by hand and it’s not that hard. They only drift about every 20 minutes or so and Vegas makes it dead simple to correct.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Jeff Stroming
    October 16, 2010 at 4:26 pm
    My Delta 1010 does have a Worldclock In. My video source is a non-genlocked composite video signal. I guess I would need a device to sync the non-genlocked video to the master clock. Any idea what this might be? And then I’d also need a Master Clock.
    I’m also guessing there are settings in Vegas to capture with embedded timecodes, or do I need a special device to do this?
