Activity Forums Apple Final Cut Pro Legacy Multican doult
  • Posted by Virgilio Troncoso on November 27, 2009 at 12:54 am
    Hi everyone.
    My question is:
    Wen i have my multicam setup,start cut angles, if i pause(space bar)my choose audio was gone and i can’t setup my audio like before with green square,it falow my cut(still together with blue square). Have another way to fix this? What i’m doing wrong? I hope you guys understand my english.Thank you very much
    Virgilio Troncoso replied 16 years, 10 months ago 2 Members · 4 Replies
  • Jerry Hofmann
    November 27, 2009 at 12:49 pm
    In the third button on the right above the pictures in your Viewer where you set up “open”, you should be able to chose to cut audio only, video only, or both. Look there to choose what you need to do…
    Jerry
  • Virgilio Troncoso
    November 27, 2009 at 1:16 pm
    Let me explain better.
    Above the viewer i have in the middle that button you said.
    My question is.
    Before, everything is setup:
    5 angle( 5 cameras), i choose angle 3 for my audio and green square is there.I started cut.The green square still in the angle 3.
    But i pause my cut for any reason,wen i start cut again,the green square fallow my choose.Like cut angle 1(blue and green still together),cut angle 5(blue and green still together).
    What i missing or doing wrong?
    Thank you
  • Jerry Hofmann
    November 27, 2009 at 2:47 pm
    Which OS are you running in? I’m seeing much the same in Leopard… but not in Snow Leopard oddly…
    This looks like a bug… Might report it. But for now you’ll have to work around it. Might put the audio in the sequence you want to keep and edit in your multiclip as a video only edit.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Virgilio Troncoso
    November 27, 2009 at 5:32 pm
    if is a bug fine.Because i thought was my falt,something i was doing wrong.
    Dosen’t matter,what OS i’m using(now is snow leopard)fallow from final cut pro 6 OS leopard ’til snow leopard.
    Thank you very much for awnser my doubt
