Activity Forums Apple Final Cut Pro Legacy multicam/track editing for multi-channel installation edit
  • multicam/track editing for multi-channel installation edit
    Posted by Angela Anderson on August 4, 2008 at 11:13 pm
    hi,
    i’m wondering if it’s possible to view two video tracks simultaneously in the canvas – i’m creating a 2 channel video installation, and need to be able to edit two video channels to correspond to one another – therefore i need to be able to see my edits simultaneously in the canvas, not one at a time like multicam mode allows for. any ideas?
    Angela Anderson replied 18 years, 1 month ago 3 Members · 3 Replies
  • Sean Oneil
    August 5, 2008 at 7:22 am
    Not possible. They’d have to be a split screen or something as part of a single sequence.
    Sean
  • Mark Raudonis
    August 5, 2008 at 3:59 pm
    How about creating a “two window” picture in picture so you can see both images simultaneously?
    Once you’re done, you can “remove attributes”, output each track as a separate sequence, and you should be good to go.
    Mark
  • Angela Anderson
    August 6, 2008 at 10:48 am
    that sounds like a great idea – any idea how i go about this?
    it’s hdv footage – so hard on the cpu, i’m assuming this would involve a good deal of rendering probably…
