Activity Forums Apple Final Cut Pro Legacy multicamera playback problems
  • multicamera playback problems
    Posted by Dylan Tucker on September 23, 2006 at 11:35 am
    Hello all. I am currently editing in multiclip mode and all was going well. However, when reopening a project, i can never get the viewer to play back in 4-up mode. The viewer will now only display the current angle, and only show the split screen (4-up) when stopped. It might just be a strange quirk, like needing to double clip the sequence first and then playing etc, but I have tried everything, and it’s driving me crazy! How can I get my multiclip splitscreen playing back in realtime mode again? I have made sure sync is open, multicamera playback is checked in RT menu, what am I doing wrong? I really need to get this sorted! Thanks a lot!
    Dylan Tucker replied 20 years ago 5 Members · 12 Replies
  • 12 Replies
  • Tom Wolsky
    September 23, 2006 at 11:40 am
    Make sure you’re playing the timeline with open ganging rather than the viewer.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
  • Dylan Tucker
    September 23, 2006 at 11:43 am
    hmm sorry, i must be thick! Do you mean the canvas ‘open’ and the viewer ‘sync off’? I’ve tried all sorts of variations.
    Thanks a lot for your help!
  • Tom Wolsky
    September 23, 2006 at 12:00 pm
    The playhead sync popups are linked, change one the other changes. They need to be set to open and you need to be playing back the timeline not the viewer.
    All the best,
    Tom
  • Dylan Tucker
    September 23, 2006 at 12:06 pm
    Oh ok. Well still no luck. It was working before. I double click the timeline, the viewer displays accordingly, but never splits. It just switches to the active cut in the timeline and its in and out points change accordingly live. No idea. Thanks for the hand anyway.
  • Tom Wolsky
    September 23, 2006 at 12:15 pm
    You have the multiclip in the timeline. Set the viewer to playhead sync open. Switch back to the timeline. With the timeline (or the canvas) the active window. Do you not see the multilcip in the viewer in 4-up or whatever you’re set to? Play the timeline. What happens in the viewer?
    All the best,
    Tom
  • Dylan Tucker
    September 23, 2006 at 1:16 pm
    yes, but as soon as i press play, it turns to full screen mode on the active angle. It is only showing 4 up when the playhead is still.
  • Tom Wolsky
    September 23, 2006 at 1:24 pm
    Where are you pressing play?
    Try trashing your preferences in case something strange has happened.
    All the best,
    Tom
  • Anders Haavie
    September 23, 2006 at 2:26 pm
    Make sure Multiclip playback is selected timeline (where the RT option is).
    Anders
  • Simon Dinnigan
    September 23, 2006 at 10:28 pm
    I have the same problem. Sometimes when I close FCP and restart it it’s fine. I definitely have everything set correctly, but it still keeps doing it.
    Simon
  • Simon Dinnigan
    September 23, 2006 at 11:23 pm
    Hi Dylan
    Select your entire multiclip sequence(s) on the timeline (Command-A), then go to Modify and select Uncollapse Multiclip(s). That should do it!
    Simon
