Activity Forums Adobe Premiere Pro Multicamera Editing / SpeedGrade
  • Multicamera Editing / SpeedGrade
    Posted by Declan Smith on February 13, 2013 at 12:38 am
    I have just cut together a multicam sequence and was hoping to use SpeedGrade to grade it but I have run into a few problems. The first attempt was to send the project to speed grade but this would have resulted in an extreme amount of DPX files (this is a long form project – 1hour 40 minutes).
    So I tried exporting an EDL which resulted in list of all the cuts but that referred to a clip that doesn’t exist (i.e. the nested multi camera sequence)., so I can get all the edits in, but no media.
    Is there a way to do this ?
    Or is there a way I can use my multi cam sequence (with all the cuts) to apply to my original multicam source (i.e. cut up the original clips as per the cuts I have made following the mulicam source selection process) or a way to batch export all the cuts as new clip media ?
    Declan Smith
    https://www.madpanic.tv
    After Effects CS5.5/ FCS3 / Canon 7D / Canon XL2 / Reason / Cubase
    “it’s either binary or it’s not”
    David Sikes replied 13 years, 7 months ago 2 Members · 1 Reply
  • David Sikes
    February 18, 2013 at 5:07 pm
    I would also like to hear about this. Any ideas from anyone?
    – David
