Activity › Forums › Apple Final Cut Pro › Multicamera editing slow
Posted by Marjo Parascandalo on March 30, 2012 at 6:07 amHi This is the second time I am using multicamera editing in FCP X. The first time was a good experience. I used two angles and both were HD at 720p. I have not experienced any problems there. But this time as I am working on another show, again with 2 angles and in Standard Definition, the cutting tends to start slowing after I reach 30 minutes and it continues to slow until it becomes unbearable. Can someone tell me what seems to be the matter? I am using an iMac 2.5 GHz Core i5 with 8GB 1333 MHz DDR3 ram and MAC OS X 10.7.2.
Marjo
Marjo Parascandalo replied 12 years, 2 months ago 6 Members · 12 Replies -
Jonas Bengtsson
March 30, 2012 at 6:29 amCheck if you are using optimized media for multicam.
Menu:
Final Cut Pro>Preferences>PlaybackCheck:
– Create optimized meda for multicam clips -
Marjo Parascandalo
March 30, 2012 at 6:36 amI am using optimized clips for multicam. Infact I start very good. It is only after I reach the 30th minute that the cutting starts slowing down gradually. I split the show in two parts. It happened in the first part, so I stopped, made another project for the second part and I started again. And again after 30 minutes of cutting it slows down.
Marjo
Steve Connor
March 30, 2012 at 12:05 pmFCPC still doesn’t like long projects , I’ve been splitting up longer shows into 20-30 minute segments for editing and then Putting them together on final export
Steve Connor
“FCPX Professional”
Adrenalin Television -
Marjo Parascandalo
March 30, 2012 at 12:28 pmThanks for the tip. I hope Apple will fix this in the near future.
Marjo
Steve Connor
March 30, 2012 at 12:54 pm[Marjo Parascandalo] “Thanks for the tip. I hope Apple will fix this in the near future.”
I’m sure they will, FCP classic used to do the same thing in it’s earlier versions
Steve Connor
“FCPX Professional”
Michael Hadley
March 30, 2012 at 2:44 pmI’ve been having a similar problem with a much shorter project. Was on the phone with Apple 4 times and even sent them files (more about that in another post).
Performance improved quite a bit when I copied the project file to my system drive (event still on external eSata drive). I had understood best practice was to keep both project and event on the same volume. But the crummy performance says otherwise.
So for now, I am back to a FCP 7 approach, with project files on my system and project media on external drives.
It might be worth a try.
Peter Schroeder
August 27, 2012 at 9:49 pmI also had the same problem with 10.0.5. so apple did not fix it!!
after 30 min of multicam editing everything slowed down untill no more work was possible
( beachball with every edit , playback stopped , only video cuts no dissolve , no fx
i have to do a programm with 2 Hrs . so i am really angry nowi noticed something when splttting up the rest ( which i hated to do because i wanted ONE timeline )
a similar project was nO problem in FCP 7)i looked at the size of the project files on the disk
30 Min = 107 MB the folder and 34MB just the Current version its got 216 Cuts ( clips)
16 Min = 17,8 MB!! the folder an 3,5 MB for the current vrsion its got 108 Cuts ( clips)SO; TEN times the size for double of time & cuts ,, Something grows very wrong here !! , exponential
BTW 8core 3,2Ghz MAcpro 24 GB RAM SAS RAID so its not the hardware 😉
ON 10.6.8 & 10.8.1 same problemPeter Schroeder
Director /Editor
Macpro 2x 3,2 Quadcore , os 10.6.2 FCP 7.01 8GB Blackmagic Decklink HD -
Marjo Parascandalo
August 28, 2012 at 5:21 amI think that the problem is not the mulicamera editing tool. I have worked in HD format and had an hour and a half project and it worked perfect. I think the problem is the kind of file you use in the timeline. In the particular project where I had the problem I was using files that I captured from a tape and files the I had filmed right on to a Hard Drive. When I eliminated the files from the Hard Drive, FCP X started working normal again. So I think it has something to do with the kind of files I was using, even if they were also .mov files.
Marjo
Peter Schroeder
August 28, 2012 at 7:50 amno compound clips . just straight cuts
its seems to be a strange kind of memory usage
making a new project : copy the first 10 min into the new project : size 3 MB totaL 10 MIN
copying the 10 min 3times into the timeline 3,9 MB total 30 mincopying the next 10 min 9 MB total 20min
copying the third part 18 Mb total 30 min
the original 30min is 34 MB
and even 30 MB should not bend down the system but ist does
Peter Schroeder
Director /Editor
