Activity Forums VEGAS Pro Multicam wizard question
  • Multicam wizard question
    Posted by Leigh Harrington on June 8, 2007 at 1:56 am
    I have a 3 camera multi-cam project where an additional track contains mostly PNGs. At the end of the project however, I put together some b-roll video (small clips)and included them on the same track as the PNGs. In other words track 1 contains the PNGs and a few b-roll clips, while tracks 2,3 & 4 are my cameras. When I tallied, I only switched between cameras 2,3 & 4. After I ran the multi-cam wizard, I moved the PNG track to the top track (above the master) as I always do. The PNGs are working fine as is some of the b-roll, however some of the master track video is missing in between the b-roll segments. Any idea why or how I can fix it?
    Edward Troxel replied 19 years, 3 months ago 2 Members · 3 Replies
  • Edward Troxel
    June 8, 2007 at 1:19 pm
    Manually move any missing pieces up and then make sure you remove any Pan/Crop adjustments to those pieces.
    Edward Troxel
    JETDV Scripts
  • Leigh Harrington
    June 8, 2007 at 6:49 pm
    Thanks. Any idea how I can avoid this problem in the future? Is it better to make your switches, run the wizard and THEN add PNGs or graphics?
  • Edward Troxel
    June 8, 2007 at 7:29 pm
    [delirious] “Is it better to make your switches, run the wizard and THEN add PNGs or graphics?”
    Yes. I typically add the “extra stuff” AFTER the master track is created.
    Edward Troxel
    JETDV Scripts
