Activity Forums Apple Final Cut Pro Legacy Multicam viewer shows only one angle
  • Multicam viewer shows only one angle
    Posted by Sawi Hsiwi on September 23, 2012 at 9:12 pm
    After creating a multiclip (only two angles), switching from sync off to open, when I start playing the track in the timeline the viewer defaults to one camera. When I pause playback both angles appear. I have experienced this with other clips but problem went away without knowing how it was fixed. (Perhaps a restart is needed?)
    How can I avoid this problem? What am I doing wrong?
    I am using Final Cut Pro 7.03, all clips are prores 422, nothing out of the ordinary. Thanks in advance.
    Grant Wilber replied 13 years, 12 months ago 3 Members · 2 Replies
  • Shane Ross
    September 24, 2012 at 1:24 am
    IN the RT menu on the timeline, make sure you have MULTICLIP PLAYBACK checked.
    Shane
    Little Frog Post
  • Grant Wilber
    September 24, 2012 at 4:17 am
    Try going thru the trashing pref’s and stuff.
    This happens to me from time to time. Got no clue why, its just random. Sometimes if I restart and trash prefs it works fine. Sometimes I just gotta wait a day and it will work again.
