Activity Forums Apple Final Cut Pro Legacy multicam video jerky
  • multicam video jerky
    Posted by Meeroo Sareew on October 2, 2008 at 2:57 pm
    I’m moving project between two Macs for color correction. I transfered project file, Capture Scratch and Render files. On parts when it was edited via Multicam video is jerky and needs to be rendered. I’m just wondering why when it plays normally on Mac where it was edited.
    Mac Quad 2.5 + OS 10.4.6 + Final Cut Studio 2 Panasonic DVX-100B
    David Bogie replied 17 years, 11 months ago 4 Members · 5 Replies
  • Andy Mees
    October 2, 2008 at 3:30 pm
    every Mac will have its own RT profile. compare the RT settings between the 2 machines ,,, see if the latter’s playback frame rate is set to Dynamic where the former is set to Full etc
    or maybe the machine you created it on is simply better spec’d for the job?
  • David Bogie
    October 2, 2008 at 3:32 pm
    Multiclip is an effect. Often requires rendering, but once it’s rendered, you can’t go back and change the editing. It’s complicated.
    The jerkiness is probably based different drive specs in your two machines, which you do not describe.
    bogiesan
  • Meeroo Sareew
    October 2, 2008 at 5:47 pm
    Thank you both, it’s much clearer now. I never thought of multiclip as effect 🙂
    I’m sorry I didn’t spec machines, I didn’t think the problem could be in that.
    Anyway, they are:
    Mac Pro 8 x 3.0 GHz, 5 GB RAM (editing)
    Mac Pro 8 x 2.8 GHz, 5 GB RAM (color correction)
  • Michael Sacci
    October 2, 2008 at 6:06 pm
    There should not be a big difference between those two systems but as mentioned multicam is normally slowed down by the drives more than the system. The RT settings can and will make a difference also.
    But when you color correct a multicam sequence (I asume with 3-way CC) you should always collapse the clips. But remember if you go back and change an angle you have to reapply the CC filter.
  • David Bogie
    October 2, 2008 at 8:43 pm
    How are you transporting the media?
    Internal drives? External FW or SATA or RAID?
    bogiesan
