Activity › Forums › Apple Final Cut Pro › Multicam undo old angle cut.
Posted by Jonas Bengtsson on March 28, 2012 at 11:57 amIm working with multicam it works very good.
Some time when you doing cuts, then you realized that you want the same angle on the both sides of the cut. No problem, just right click, option click or what ever so you got your preferred angle.
But how do you heal the cut between those to cuts with the same angle?
Fabien Daguerre replied 14 years, 5 months ago 4 Members · 9 Replies -
Jeremy Garchow
March 28, 2012 at 1:00 pmYou can’t simply delete the cut point for some reason anymore.
You would have to trim it out for now, or simply leave it as is.
Fabien Daguerre
March 28, 2012 at 1:38 pmI could be wrong, but you can select your cut by clicking on it then hit delete.
The angle of the clip before the cut will be applied to the new “cut-healed” clip. -
Fabien Daguerre
March 28, 2012 at 6:04 pm -
Mark Morache
March 28, 2012 at 7:14 pmTo heal cuts, I’ve been selecting the right edge of the first half, with a one sided trim, then I use the down arrow to jump to the end of the second clip and extend the clip to the end the second clip, then I select and delete the second clip.
It mostly works, so long as the second clip doesn’t have anything attached to it.
Don’t live your life in a secondary storyline.Mark Morache
FCPX/FCP7/Xpri/Avid
Evening Magazine,Seattle, WA
https://fcpx.wordpress.com -
Jonas Bengtsson
March 29, 2012 at 11:59 amThanks!
It was the obvious, mark and back space. I have a big keyboard so I tried with “delete” key first, and said some beeeeping words in swedish, until I tried back space 🙂
Fabien Daguerre
March 29, 2012 at 2:38 pmWell, It’s my fault, I had forgotten the English word for that key !
Anyway, glad it could help you.
