Activity Forums DaVinci Resolve Multicam Synchronisation
  • Multicam Synchronisation
    Posted by Dave Edwards on December 12, 2018 at 10:22 am
    Sometimes I can’t use audio or timecode for synchronisation and need to choose a visual clue at an arbitrary point in each of the clips contributing to a multicam track.
    In Avid I can define inpoints in the clips and the resulting multicam track is then also usable on the timeline before the in points.
    In Resolve the resulting multicam track seems only to be available from the inpoints forward or from the endpoints backward. Is there another way to do this?
    Dave Edwards replied 7 years, 9 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    December 12, 2018 at 12:07 pm
    Check out page 266 and onwards in the latest manual.
  • Declan Smith
    December 12, 2018 at 12:11 pm
    You can sync using markers. In the media page, click on ClipA and scroll through to where you want the sync point, then press m. This will drop a marker. Next click on ClipB and scroll through to where you want the sync point in that clip, and press m to drop a marker. Now select both clips, click create multicam clip and then in the sync drop down, select marker. Select you camera angle or camera or clip name for the metadata and then create. This should do what you’re looking for.
    Declan Smith
    https://www.madpanic.tv
    Davinci Resolve / FCPX / Adobe CS6 / FCS3 / Zoom F8 / Roland R26 / Canon XLH1 / Canon 7D / Reason 10 / Cubase
    \”it\’s either binary or it\’s not\”
  • Dave Edwards
    December 12, 2018 at 1:35 pm
    Thank you very much.
