Activity Forums Apple Final Cut Pro Multicam sync issues
  • Multicam sync issues
    Posted by Kristel Ottis on March 12, 2014 at 8:10 pm
    i’m having a lot of trouble doing something very simple: creating a synced multicam clip based on markers.
    I’ve been able to do it in the past and it seemed very simple. Yet, I seem to have hit a wall — probably due to lack of experience with FCPX.
    I have three clips. They all have matching time codes, but I want to sync with markers just to be safe. I add markers in the Event Browser.
    I select all three, choose make multiclip and… end up with a Timeline where apparently there’s only data in Camera 3 (even though in the Event Browser there’s nonstop video in all three).
    The only places where I have one frame of video is where my markers are.
    What am I doing wrong here? How do I get these angles to sync (and display) properly? This should be incredibly straightforward.
    Kristel Ottis replied 12 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    March 12, 2014 at 8:55 pm
    Before you make the multiclip, select the three clips and choose Mark > Clear selected ranges (or just hit option-x).
    Then make the multiclip.
  • James Cude
    Do you have Angle Synchronization set to First Marker on the Angle?
  • Kristel Ottis
    March 12, 2014 at 10:03 pm
    You are an absolute lifesaver. I can’t believe it was that simple.
    Why on earth would adding a marker also add a range? Very strange.
  • Jeremy Garchow
    March 13, 2014 at 1:29 am
    Its pretty easy to add a range without noticing.
    This was a feature that was added later to FCPX. The first few versions would clear the range automatically after leaving the clip.
    Jeremy
  • Kristel Ottis
    March 13, 2014 at 11:49 am
    While I’m here, do you know of any way to zoom into the viewer in the Event browser, to look at the waveform more closely?
    Poking around a 2hr video to find markers isn’t very efficient…
  • Jeremy Garchow
    March 13, 2014 at 12:16 pm
    A few options:
    -In thumbnail view and with the event browser selected, hit shift plus and shift minus. Shift-z zooms you all the way back out.
    -In thumbnail or list view you can jump from marker to marker using control semi colon and control comma.
    -You can simply twirl down the list view and see the different markers.
    -if you’ve added market text, you can search for it in the Browser search field
    Jeremy
  • Kristel Ottis
    March 13, 2014 at 1:43 pm
    Hmm. When I use shift plus and shift minus in thumbnail view in the Event Browser, I get an error beep and the time code window looks like this:
  • Jeremy Garchow
    March 13, 2014 at 2:04 pm
    Did I say shift?
    I, but of course, meant command.
  • Kristel Ottis
    March 13, 2014 at 2:15 pm
    Ha. Nice. Thought I had tried all the variations, but it worked with Cmd.
    Maybe I can live with X after all!
