Activity Forums Apple Final Cut Pro Multicam split screens
  • Multicam split screens
    Posted by Gayle Anderson on December 17, 2023 at 5:31 pm
    I’ve recorded a basketball game with a few cameras. One is pointed at the scoreboard. I’m able to sync all the cameras and switch between them without problem. I’d like to keep the synced scoreboard in a little box in the corner while switching the angles of all the other cameras. I’ve searched for video tutorials about how to do this, but can find none. Is this possible? How, if so?
    Gayle Anderson replied 2 years, 8 months ago 3 Members · 3 Replies
  • Doug Metz
    December 18, 2023 at 6:34 pm
    There is no way to switch video angles and also keep a specific angle in the same multicam clip hot at all times. Just overlay the scoreboard clip once you’ve done your multicam cut, and scale/position as desired.
  • Ben Balser
    December 19, 2023 at 8:59 pm
    Finish editing the game. Then duplicate the first clip in the timeline above itself (opt-drag). Change that clips angle to the scoreboard. Drag its tail to the end of your edit. Resize and position as needed. This way you keep everything in sync. Yes, the scoreboard will need to be a resized clip above the multicam edits.
  • Gayle Anderson
    December 20, 2023 at 5:56 am
    Thank you both for offering these solutions. I will give them both a go.
