Activity › Forums › Adobe Premiere Pro › Multicam Selection [ASAP]
Posted by Cole Yakimishyn on September 15, 2013 at 10:20 pmI’ve just used Multi-cam to make a series of cuts in my video… I forgot to balance audio before doing so so now its all cut into pieces and would take me forever to select each piece. (eg I have 4 sources and i need to just select all of the cuts that involve MC2’s audio.) Is there a certain thing i can do to select them all and balance them? If so please respond asap. 🙂 thanks
Paddy Uglow replied 12 years, 11 months ago 4 Members · 13 Replies -
Ivan Myles
September 15, 2013 at 11:43 pm– Place the audio from each clip onto the same track(s).
– Create a submix track and in the Audio Mixer panel map the track(s) with the clips to the submix.
– Adjust the audio submix track as desired. -
Cole Yakimishyn
September 16, 2013 at 12:29 amOk im a bit confused. Can you give some more detailed instructions? Thanks
Al Bergstein
September 16, 2013 at 3:23 pmIvan, do mean place all the clips on one track, one after the other? You are describing a process that is all done in Pr , correct? Not in Au? Somtimes posts are not as clear as video. Thx. i’m sure I’ll face this at some time. Usually my sound tracks in multicam are not used for main audio track. I almost always record to an external recorder when shooting multiple camers. But you never know.
Cole, do you really need all the tracks individually? Often B cam audio is discarded.
Al
Ivan Myles
September 16, 2013 at 4:26 pmThe process is performed in Premiere Pro. The clips can be placed on multiple tracks. All tracks with the desired clips will need to be mapped to the submix track. Please refer to the following for more information:
Premiere Pro / Advanced Mixing
Ivan Myles
September 16, 2013 at 4:28 pmPlease provide more information, perhaps with a screen capture of your timeline, and more specific questions.
Cole Yakimishyn
September 16, 2013 at 10:38 pmYes I do need all of the audio. This is not like a 4 camera rig. Its 4 different pieces of gameplay.
https://gyazo.com/d1f437cf185c676ecb347eec98b345c5
As shown in the screen shot above, i have already cut the clips but i need to balance the audio. I dont want to go back and re-cut everything. Is there a easy way to do it?
Ivan Myles
September 17, 2013 at 12:15 am– Right-click on the track header area in the Timeline panel and select the option to add a new track. In the dialogue box, enter ‘0’ new video tracks, ‘0’ new audio tracks, and ‘1’ new audio submix track.
– In the Audio Mixer panel, change the mapping of Audio 1 from “Master” to “Submix 1.”
– In the Audio Mixer panel, adjust the volume and panning of Submix 1 as desired. This will change all of the clips in Audio Track 1.
– If you would like to adjust the audio settings at different points in the sequence, go to the Timeline panel and add keyframes to the track for Audio Submix 1.
The link posted above provides more detailed instructions for each of these steps.
Cole Yakimishyn
September 17, 2013 at 1:21 amOk so how do i change the levels of just one MC. For example, all the audio for MC3. Because all of the sources have different audio levels.
Ivan Myles
September 17, 2013 at 3:13 amCreate an audio track and an audio submix track for each camera and move the clips accordingly. For example, move audio for all MC1 clips onto audio track 1, and map the track to audio submix 1. Move the audio for all all MC2 clips to audio track 2, and map the track to audio submix 2. etc. Then adjust the submix tracks as required.
Cole Yakimishyn
September 17, 2013 at 4:05 amOk i can do that but is there a way to select all of the cuts for one MC? I have over 300 cuts and it would take years to sort thru and drag everyone.
