Activity › Forums › Adobe Premiere Pro › Multicam question
  • Multicam question
    Posted by Sebastian Plamadeala on May 14, 2008 at 2:07 pm
    Hello.
    Is there any way premiere pro cs3 can display the audio waveform of a multicam sequence? (without any other workaround, like taking the audio out of the multicam nest sequence and then replacing the the linked audio of the edited multicam sequence?
    i need to sync 6 cameras togheter, and for this, i need to multicam edit the first 4 cameras, and then edit the other two togheter with the fianl edit of the first cameras.
    it’s such a bother having to eye-sync everything again…
    thank you,
    Sebastian Plamadeala replied 18 years, 4 months ago 2 Members · 2 Replies
  • Jon Barrie
    May 15, 2008 at 2:49 am
    If you hit enter to render the timeline will render the audio first, then any video that requires rendering. This will let you see the waveform, this is how to see the waveform for nested sequences, as Multi-cam is essentially a variation of nesting…
    – jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • Sebastian Plamadeala
    May 25, 2008 at 9:23 pm
    hey. thanks for the reply. i did render the timeline, but no waveform showed….:( and it shows the audio of another clip if i add it in the timeline, so it’s not an option that i missed to enable…pls help
