Activity Forums Apple Final Cut Pro Legacy Multicam question
  • Multicam question
    Posted by Dave Fisher on April 7, 2006 at 7:40 pm
    Hi:
    I am editing a three camera shot using multicam..it worked fine the first few seesions, but now I can’ seem to get the 3-screen sync to work while playing on the timelime to do live switching..it cuts to the source camera, and when I stop , it jumps to the three-screen in the browser..I swear it used to show all three cameras while playing and switching on the timeline…any ideas what I’ve ***$# up..?
    thanks
    dave
    Dave Fisher replied 20 years, 5 months ago 2 Members · 2 Replies
  • Creative Animal jan
    April 7, 2006 at 9:03 pm
    go to pulldownmenu Final Cut Pro — Systems settings -> TAB effects handling. Make sure the handling for the codec you are working in is set to Final Cut Pro, not to Decklink / AJA or any other hardware handler.
    that should do it!
    If that doen’t work, then you might try removing your renderfiles of the multiclips you’re using. Somehow multicam only works fluently when the “render FULL” has not been done yet.
    regards
    Jan
  • Dave Fisher
    April 7, 2006 at 10:17 pm
    HI:
    Thanks for the tips! You’re right, I had rendered everything…got it working now..thanks!
    Dave
