Activity › Forums › Adobe Premiere Pro › Multicam project Warp Stabilizer requires pixel aspect ratio to match sequence.
  • Multicam project Warp Stabilizer requires pixel aspect ratio to match sequence.
    Posted by David Jackson on September 30, 2020 at 5:05 am
    Hi
    I am looking for help with applying warp stabilizer effect into a multicam edit (short wedding). Particularly for my hand held camera clips (DSLR).
    I have a red bar and the words “Warp Stabilizer requires pixel aspect ratio to match sequence (fix by nesting)”.
    So I followed a youtube tutorial and nested the clips from the timeline where I can see the various cameras lined up. No good.
    I asked Adobe Premiere support yesteday and they said the fix was:
    “Could you please right click on the clip and click on reveal in project, it will be highlighted in project bin. Right click on clip in project bin and click on new sequence from clip.
    Once you get the clip in new sequence panel by above process apply wrap stabilizer in that sequence.”
    I’m still at a loss with what the work flow should be for multicam, OR shoudl I jsut delete and re-insert those clips from that camera and then nest and apply the stabilizer over again?
    Can anyone give me straightforward steps for a multicam situation?
    Ta
    David Jackson replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
