Activity Forums VEGAS Pro Multicam Problem
  • Multicam Problem
    Posted by Linda O’connell on July 13, 2009 at 7:27 pm
    I have used Mulitcam editing quite a bit in the past.
    But now I am running into a problem..
    I have one main audio track attached to camera A, No audio attached to Camera B, I hit select all, Enable Multicamera Track. I then get a message saying “All envelopes, motions will be deleted (or something to that effect), proceed?” I hit “YES”
    Then the whole program turns whitish and it the hour glass runs and runs and then it says, “Sony Not Responding”
    I have defraged, I have shut down, I even went on vacation for 4 days and it still is doing it ;(
    Any ideas? The only thing I am thinking is I had the two tracks set up as track motion so I could see both them on the screen to get them synchronized. Could that be part of the problem?
    Martin Phillips replied 17 years, 1 month ago 3 Members · 2 Replies
  • John Rofrano
    July 13, 2009 at 7:32 pm
    From the sound of the warning message it might be. I would remove the track motion since you don’t need it anymore and try again. (it’s the only way to know for sure)
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Martin Phillips
    July 13, 2009 at 7:48 pm
    Try not selecting all. Just the 2 video tracks. Martin.
