Activity Forums VEGAS Pro multicam – one cam only showing
  • multicam – one cam only showing
    Posted by Roger Bansemer on June 14, 2010 at 12:15 pm
    Only one of my cams is showing up in Multicam mode at a time even though three cams are on the multicam timeline. If I move my mouse to another clip from another cam it will show up but I can’t get the 3 cams in preview at the same time.
    Nigel O’neill replied 16 years, 2 months ago 2 Members · 1 Reply
  • Nigel O’neill
    June 18, 2010 at 1:12 pm
    You need to select all the video tracks. It does not do it for you.
    What you need to do is put all your clips on different tracks i.e. one for each camera. Sync them up and then just go to Edit and Select all. After that go to tools, go to the multicam window and hit create multicam timeline. Then enable multicam editing. Your takes will appear as diiferent windows.
    You can also ctrl-click to select particular video tracks instead of select all.
    Personally, I prefer to use Vasst UltimateS.
    Intel i920, 12GB RAM, ASUS P6T, Vegas Pro 9 (X64), Vista x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S 4.1
