Activity Forums Apple Final Cut Pro Legacy Multicam merged clip problem :(
  • Multicam merged clip problem :(
    Posted by Mark Pommett on October 18, 2005 at 6:02 pm
    I created a two cam muliclip. Cam track A is a merged clip with DAT audio. When I create the multiclip and switch back and forth between A and B via the viewer the DAT sound from Camera A is no longer in sync. I never had this problem when using clips with on-camera sound.
    Thanks in advance.
    Tippytink replied 20 years, 9 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    October 19, 2005 at 2:16 am
    Might try exporting a self contained QT movie of the merged clip, import that and use it for the Multiclip… might help.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Tippytink
    December 15, 2005 at 2:22 am
    I am having the same problem and I do not have the option of exporting each one as a QT since that would take way to long with the amount of footage we have as well as it creating a problem with the online process. Any other suggestions? Is this a bug? Any word of this getting fixed ASAP??
    Melissa
