Multicam lags in fast forward…
Posted by Austin Brock on February 18, 2015 at 9:14 pmHey CC,
I edit a video with two sources in Sony Vegas 12 and if I try to play at 2.25x speed, it starts to get choppy and video lag. It’s not smooth at all.
Any suggestions on how to resolve this?
Stephen Mann replied 11 years, 7 months ago 4 Members · 3 Replies -
Nigel O’neill
February 19, 2015 at 12:37 pmWhat is your source? AVCHD, DV or HDV? AVCHD is the most processor intensive to play back, and the only real solution is to buy a system with the fastest CPU you can afford. You really cannot edit multiple tracks of video smoothly with anything less than an high end i7 CPU. I edit 4 tracks of multicam with a mix of HDV and AVCHD video sources and my system only just keeps up. The preview is a bit laggy, and I switch between Preview Full and Draft Full
You could use a product such as Gear Shift to create proxies, or upgrade to Vegas 13 which I believe has a native capability to generate proxy files.
My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
Bob Peterson
February 19, 2015 at 3:24 pmIn addition to telling us what format is used by the source files, you should also tell us a lot more about your computer.
Stephen Mann
February 20, 2015 at 5:21 pmAnd where are you seeing the lag, preview or rendered output? In preview try a lower resolution. What happens in preview is that Vegas has to create a new i-frame for each frame displayed, and to do that it has to start from the prior i-frame then work its way up to the current frame. That takes a lot of processor horsepower to do it in real time.
Steve Mann
MannMade Digital Video
http://www.mmdv.com
