Activity › Forums › Adobe Premiere Pro › Multicam lag in Premiere Pro CC?
  • Multicam lag in Premiere Pro CC?
    Posted by Ceylan Le compte on August 14, 2015 at 2:26 pm
    Hey, I had this problem for a long time, and because of this, I even upgraded my computer
    here are the specs
    I7 5960X
    16 GB RAM DDR4
    GTX980
    Samsung 850 SSD
    So I was trying to use multicam with 3 cameras, each file with a bitrate of about 8mbps. And when I use the multicam window, it lags.
    It will play fine for the first 5 seconds or so, and then it starts losing frames more and more.
    At first I thought my computer wasn’t powerful enough (I7 and a GTX760). I upgraded, nothing changed
    Then I thought maybe it’s the harddrive, So I upgraded to an SSD and redid the whole system, put the files in the SSD, nothing changed.
    On a computer like this, it should easily handle 3 cameras no problem, not to mention those files are 720p 30fps.
    When it starts lagging, I checked my taks manager, RAM is about 60%, SSD 10%, cpu 10%
    both Cuda acceleration and CPU only does not change the outcome.
    Has anyone experience the same thing? If so, how did you fix it?
    Thank you 🙂
    David Roth weiss replied 11 years, 1 month ago 2 Members · 1 Reply
  • David Roth weiss
    August 14, 2015 at 4:31 pm
    Grab a screen capture of your sequence settings and post that here please.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
