Activity Forums Apple Final Cut Pro Multicam issue, any thoughts are appreciated…
  • Multicam issue, any thoughts are appreciated…
    Posted by Christian Friis on August 7, 2015 at 10:23 am
    I’m trying to sync 2 cameras in FCPX, talking head footage, 2 angles. I use the auto function syncing by audio, but the result is that the 2 clips are placed one after the other. Any ideas why this happens? Thanks in advance!
    Christian.
    Robin S. kurz replied 11 years, 1 month ago 2 Members · 2 Replies
  • Christian Friis
    August 7, 2015 at 11:03 am
    Solved! The issue was that the 2 cameras had the same name (as they were same brand and model). So I changed the camera name + the angle name. Dont know which of the 2 info points did it.
    https://www.oddresort.com
  • Robin S. kurz
    August 7, 2015 at 11:26 am
    [Christian Friis] “Dont know which of the 2 info points did it.”
    It will have been the angle name. Setting a different angle ORDER in the setup would have done it also.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
