Activity › Forums › Apple Final Cut Pro › Multicam in 10.0.8 kinda messed up?
David Powell replied 13 years, 2 months ago 6 Members · 12 Replies
Tim Jones
June 19, 2013 at 3:41 pmDavid, what do you consider “long”? I ran some learning tests using a 30 minute set of shots from a seminar I gave and 2 of the cameras were stopped multiple times during the session because of small SD cards, but everything synced up – even with the gaps.
Are the Gap’d shots from the same camera being imported as separate clips? If so, make sure that you set the “Camera Name” to the same camera name in all of the separate clips. Next, select those and your other clips (including your external audio) and create a new “Multicam Clip” selecting “Camera Name” for the “Angle Assembly” and check “Use audio for synchronization”.
This worked first time out for my test angles.
Or, have I missed something in the discussion?
Tim
Tim Jones
CTO – TOLIS Group, Inc.
https://www.productionbackup.com
BRU … because it’s the RESTORE that matters! -
David Powell
June 19, 2013 at 4:40 pmCouple hours or so. I use plural eyes though. Syncs in seconds what final cut could never sync or would stall it forever.
