Activity › Forums › Apple Final Cut Pro Legacy › Multicam Flickering
  • Jimmy Guarasci
    March 24, 2006 at 2:21 pm
    what are your playback settings?
  • Nebonmedia
    March 24, 2006 at 6:56 pm
    Here are two screenshots of both the problem and the playback settings.
    https://www.nebonmedia.is/error/screen1.png
    https://www.nebonmedia.is/error/screen2.png
  • Shane Ross
    March 24, 2006 at 10:26 pm
    I’m sorry, but I see a nice crisp image.
    What should I see, and where?
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Nebonmedia
    March 24, 2006 at 10:56 pm
    On the frame you see (Camera 1,2,3 etc.) That should be small mutlicam frames.
    The “Active” clip goes over the all four frames so I cant see what I angel I should
    switch to.
    The thing is, I cant see the four frames but I can choose them, that
  • Tom Wolsky
    March 24, 2006 at 11:03 pm
    Make sure you have playhead sync set to open and that you’re playing back the timeline NOT the viewer.
    The PowerBook will probably not be able to give you good multicam playback with four cameras. You need a faster computer with faster drives.
    All the best,
    Tom
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” DVD
  • Nebonmedia
    Ok …….
    I imported some standard DV footage, and made another multiclip from that four clips.
    And … everything is working fine, for “now”. The old clip that I had problems with
    is working, but I never know when this could happend again.
    If someone have experienced this problem, please write something about it here 😉
    Thanx guys for all the feedback.
