Activity Forums Adobe Premiere Pro multicam export to after effects
  • multicam export to after effects
    Posted by Jeremias Nussbaum on January 22, 2007 at 5:21 pm
    seems like you can’t just copy a multicam clip into after effects?
    everytime I try this it just copies the first clip, not the other three clips I cut with the multicam function.
    Do I have to split them up and how would I do this the fastest way?
    Anyone any idea?
    Kyle Dettman replied 14 years, 10 months ago 6 Members · 8 Replies
  • 8 Replies
  • John Baumchen
    January 22, 2007 at 5:26 pm
    Have you tried importing the sequence?
  • Jeremias Nussbaum
    January 22, 2007 at 5:31 pm
    hey,
    same problem. just imports the whole footage and the cut footage is just the first clip. the problem seems to be that multicam editing doesn’t produce proper clips. now I try to figure out to create proper clips, but still searching….
    any ideas?
  • John Baumchen
    January 22, 2007 at 5:45 pm
    Do you have Adobe Production Studio?
  • Jeremias Nussbaum
    January 22, 2007 at 6:05 pm
    no. Getting a bit confused, just exported the multicam-sequence, it only exported cam 1…? something’s wrong here..
  • Tclark
    January 22, 2007 at 6:08 pm
    I had the same kind of issue. If you try and cut and paste it will give you the whole video instead of the clip. Which is frustrating.
  • Daniel Ramirez
    February 14, 2009 at 6:54 pm
    Unfortunately. After Effects cannot import Premiere’s multicam clips with the edits applied. It imports the multicam clip before the edits.
    This same problem will happen if you do a “Replace clip with After Effects Composition” in Premiere.
    I’m trying to get this limitation better documented in our help system. This is a workflow that’s valuable to me as well, so I’ll be advocating adding support for multicam clips in AE’s Premiere importer as we move forward.
    -Dan Ramirez
    AE QA
  • Wes Sutton
    October 30, 2010 at 4:10 pm
    It looks like this is still a problem in CS5. Kind of disappointing. I create music videos with multicam all the time and I have to render an intermediate version to bring into after effects. Not being able to use the dynamic link is very frustrating.
  • Kyle Dettman
    November 8, 2011 at 3:46 pm
    One fix I found is time consuming, but gets the job done.
    From Premiere, right-click your multicam clip and select Replace with After Effects Composition.
    In After Effects (5.5), your multicam clip will appear as a pre-comp. Just open the pre-comp, and turn off the tracks you don’t want to use.
    Each instance will generate a new multicam pre-comp.
    Kyle
