Activity › Forums › Apple Final Cut Pro Legacy › multicam editing/sound clip problem
  • multicam editing/sound clip problem
    Posted by Andre Schaefer on June 15, 2010 at 3:47 pm
    Hi there,
    I am facing some trouble synchronizing a sound clip that I recorded on an external sound recorder to my multicam edit. I have tried to sync the clips via in- and out points, but when place the multiclip into a sequence the sound is not where it should be. Actually it is off by 20 or more seconds. The video footage is dv pal and the sound has been recorded as a pcm file (.wav) with 48khz and 16bit. The video clips are in sync, the sound isn’t.
    Any idea what I’m doing wrong?
    Thanks for your help!
    Andre Schaefer replied 16 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
