Activity Forums Apple Final Cut Pro Multicam editing without having cuts on camera audio
  • Multicam editing without having cuts on camera audio
    Posted by Adam Berch on September 26, 2015 at 1:48 pm
    I have 2 cameras that were recorded with audio and 1 H4N separate audio. I have already synched them up. I am about to do a Multicam edit in FCPX. If I want to use one of the in-camera audio sources as my main audio (I’m going to monitor that one when I edit in multicam) and not have it leave a cut every time I switch cameras in muticam, how can I do that?
    In other words, I just want to cut the video without having cuts on the audio portion so I can tweet the audio later.
    Thanks in advance
    Bret Williams replied 10 years, 12 months ago 3 Members · 2 Replies
  • Mark Landman
    September 26, 2015 at 4:35 pm
    Press one of these hotkey combinations to set the edit mode you want
    Shift/Option-1: Cut&Switch Mulitcam Audio and Video
    Shift/Option-2: Cut&Switch Multicam Video Only
    Shift/Option-3: Cut&Switch Multicam Audio Only
    Then press the number key of the track you want to switch to.
    The edit mode will remain selected until you change it again. You don’t need to select it before every edit.
    Mark Landman
    PM Productions
    Champaign, IL
  • Bret Williams
    September 26, 2015 at 5:09 pm
    It will always leave a audio cut unfortunately. Once the content is locked I tend to turn off audio for the others and drag out the first clip audio underneath until you reach the next change in audio source. Makes mixing audio much easier later. More visual as well.
