Activity › Forums › Apple Final Cut Pro Legacy › Multicam Editing dropouts & error message
  • Multicam Editing dropouts & error message
    Posted by Pat Defilippo on September 7, 2006 at 1:17 am
    Hello,
    This is my first crack at Multicam Editing in FCP and it was going well for the first 5 edited minutes but then I had to re-sync the clips on a camera pick-up and it’s all falling apart!
    I’m having two problems:
    1) The video when playing back is dropping frames to the NTSC monitors via the AJA Io LA box, something that it never does in regular editing, although the video in the Viewer and Canvas windows is just fine.
    2) I’m now getting an error when I try to switch an angle that says “Insufficient content for edit”.
    Is there an easy fix here or do I just need to re-sync a new Multiclip and try it again?
    Thanks in advance,
    -Pat
    G5 Quad 2.5 Desktop with 4GB Ram, 500GB HD & Fiber Card ~
    30″ Cinema Display & 17″ Sony SVGA ~
    Swift Data 200 Internal 1.6TB SATA II RAID 0 ~
    AJA Io LA ~
    Final Cut Studio ~
    Sony UVW-1800 Beta-SP ~~~
    P D Post Productions, Inc. ~
    TV~DVD~VHS~CD~WEB
    for Corporate Communications, Commercials, Infomercials, Television Programs, Family Occasions since 1983 ~
    E-mail PD@PDPost.com ~
    Website http://www.PDPost.com ~
    Business/Cell Phone (847) 275-5671
    Pat Defilippo replied 20 years ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    September 7, 2006 at 1:28 am
    What’s the format of the video, and how did you “re-sync” the camera angle? How many total angles?
    Also post the OS, QT, FCP versions you are running.
    Jerry
  • Dan Riley
    September 7, 2006 at 2:49 am
    Yeah, what do you mean by “I had to re-sync the clips on a camera pick-up ” ?
    Re-sync what? …where?
    I’ve edited many 4 camera shows with FCP’s multicam and it works well.
    Some would say even better than AVID, especially in how easy it is to make
    the multiclips, (groups in AVID speak). My only beef is you can’t match frame
    to the source clip from a multiclip timeline. Hopefully this will be fixed.
    I do all my multicam roughcuts at DV. This works well with my SATA RAID.
    Then I uprez to uncompressed and have had no trouble, except for
    still frames, but I digress.
    What codec are you using?
    Dan
  • Pat Defilippo
    September 7, 2006 at 3:12 am
    Hi Jerry and Dan,
    Thanks for your help with this.
    I did figure out why I was getting the “Content” error. When I had to re-sync (meaning that, at around the 5 minute mark, one of the three cameras was accidentially turned off and then back on a few seconds later) the cameras (which created a second Multiclip), I didn’t get a good match frame after making the Multiclip and learned this after about three camera switches. Good point, Jerry, about the inability to match frame because that might have helped me here. When I tried to adjust the one camera after making the three camera switches off of that second Multicam clip, that’s when I repeatedly got the error.
    I finally put the second Multicam clip on a new track and extended the In Point back to the head of the first of the new cuts (of the three). THEN I re-synced the camera and re-entered Multicam editing mode, using the three cut points on the original video track as a guide as to when and where to cut (since I had already done them anyway). I think I got the error becuase I re-synced the shots AFTER making the three cuts becuase goomg bacl amd syncing it perfectly from the first cut got rid of that error.
    The other issue, though, is the dropped frames that are still frequently happening. I am using the AJA Io LA 8-Bit Uncompressed codec and I have three camera angles. I’m running the latest and greatest versions of OS (10.4), QT and FCP (5.1.1). The only thing I can think to do at this point is to finish the 20-minute wedding multicam and then check everything in the Render All menu and let it render everything. Do you think that might clean out the black frames (which are also dropping audio)?
    Thanks again,
    -Pat
  • Dan Riley
    September 7, 2006 at 4:40 am
    Go ahead and render now, just to see if your current timeline plays correctly.
    Highlight a few minutes worth and do a ‘render all’ so you end up with the
    blue line on top of the timeline. Remember, once you render you can’t
    see the three cameras playing back together in a multiclip. So after you
    do this test, just clear the render by checking and unchecking the green button
    on the video track. Then you can see the multiclips in real time again.
    dr
  • Jerry Hofmann
    September 7, 2006 at 1:04 pm
    Down the line… there is a way to keep that on then off then on camera in the same multiclip… put it in sync for it’s start, then add an edit where it stopped. Drag that portion later, fill the hole on that track with slug. Then export that track only as a self contained QT movie… reimport that file and use it. What will happen is that it will just go black during the time it wasn’t recording.
    Jerry
  • Pat Defilippo
    September 7, 2006 at 2:04 pm
    Thanks for the ideas and advice!
    I’ve got to jump out of this project today for another one (an actual paying job!!!), but I should be back at it tomorrow. I’ll let you know how it ends up going.
    Have a great day,
    -Pat
  • Jerry Hofmann
    September 7, 2006 at 10:20 pm
    Keep the source sequence if you do this exported with black in the middle file… you can re create the export again if necessary someday..
    Jerry
  • Pat Defilippo
    September 8, 2006 at 6:40 pm
    Thanks again, Dan and Jerry!
    Jerry, that last minute tip of saving a copy of the sequence came in just as I was starting up the “Render All” with “Full” checked (thanks again!). It took about 26 minutes for the 23 minute, three-camera switched edit.
    So, now I have the duplicate with a green bar across the top which frequently drops frames and the master with a blue bar across the top which, for the first five minutes anyway, has not dropped any frames.
    I would say that back in the linear days when I used Multicam Mode on a Grass Valley or a CMX editor that it was pretty good, but no where near as flexible as FCP’s Multicam Mode. After doing this first one, there are some gotchas that I know to stay away from for next time (like changing an in-point after doing a couple of switches, which gives the aforementioned error message), but all in all I’m very happy with Multicam Mode. I was easily able to go back and add some split-screens using a second video channel, easily syncing to a different angle and keyframing the move.
    Now I just have to find enough paying work to keep me busy!
    Thanks again for your help, Dan and Jerry,
    -Pat
    AJA Io LA ~
    Final Cut Studio ~
    TV~DVD~VHS~CD~WEB
