Activity Forums Adobe Premiere Pro MultiCam edit with more than 4 cams
  • MultiCam edit with more than 4 cams
    Posted by Evan Cowan on July 20, 2008 at 10:20 am
    i am about to shoot a live music concert with 9 cams.
    will also shoot a rehearsal, with 8 or 9 cams.
    the show is almost 2 hours long.
    i did this last year and manually edited 18 tracks of video, took a long time, but looked nice.
    anyone done a multicam edit with more than 4 cams?
    is there a plugin for premiere that does more than 4?
    i have premiere pro CS3 for mac and PC.
    thanks!
    Andy Benfield replied 18 years, 1 month ago 3 Members · 2 Replies
  • Phocas Kroon
    July 22, 2008 at 7:48 pm
    Multicam edit is nice for an interview with 2 or 3 camera’s and insert material.
    For a concert with 4 camera’s it is very difficult to switch to another camera exactly on the music. So you need a lot of time to make corrections after the multicam edit.
    I advise you to edit the concert with 9 camera’s manually. It is time consuming indeed, but you have a lot more control on the process and less corrections.
    Tip: Create a temporary picture-in-picture screen of all tracks so you can see all camera’s during editing.
    Good luck
    Phocas Kroon
  • Andy Benfield
    July 23, 2008 at 1:55 pm
    Are all your cameras manually controlled or do you have any locked off? I often do 6-cam edits with 2 fixed-cams so I can multi-cam edit in CS3 on the 4 manned-cameras, then 2 other tracks (above the multi-cam edit) that are turned invisible until I need to cover bits where my multi-cam wasn’t wanted.
    I’d recommend this method as I actually find it easy to cut the multi-cam edit on the beat so it’s much quicker than manually editing 6 cameras (or 8 or 9).
    Happy to give more advice if you want it.
    Andy
