Activity › Forums › Apple Final Cut Pro Legacy › multicam edit sync points question
  • multicam edit sync points question
    Posted by Michael West on August 9, 2010 at 11:39 pm
    Hola!
    When I attempt to find a sync point to do a 3-camera multicam edit, can I use any common point from the 3 timelines to match things up?
    If I found a common sync point farther down the timelime (say, 20 to 30 seconds in) would this still be usable?
    Most of the tutes I’ve read/watched have used the standard timecode match-up(don’t have that)or a clapboard (didn’t have that when I shot the footage; was still new to editing at that point) and these techniques are usually based on things found nearer the beginning of the footage.
    Thanks for any help you folks can provide.
    Michael
    Michael West replied 16 years, 1 month ago 2 Members · 2 Replies
  • Michael Sacci
    August 10, 2010 at 12:04 am
    what happened when you just tried it?
    it makes no difference where the In or out point is the video, you just need to find the common frame. If on angle A it is 5 minutes in, and on angle b it is 3 minutes in. When you play it back the will be 2 minutes of black on angle A
  • Michael West
    August 10, 2010 at 3:07 am
    Michael:
    Thanks.
    I didn’t want to dive in until I got some good advise.
    Time to play.
    Michael
