Activity Forums Adobe Premiere Pro Multicam Edit Questions
  • Multicam Edit Questions
    Posted by John Watts on December 10, 2018 at 9:57 pm
    Beginning the process of switching over to using multicam to edit my 10 cam show. I’ve been manually cutting this one hour show on the timeline.
    As I practice, I’ve learned that I can only run 4 or maybe 5-6 cameras before system lag becomes an issue.
    It works pretty good, however, one thing.
    These clips are synced by in points, no luxurious matching timecode.
    There are several more clips, not included in the processed clip bin, that I need to match frame to cut in audience reacts/wide shots/etc.. Can I match frame these clips to the sequence (or can I?) Of course I can find these match frames manually, but, that’s slow and painful as there are quite a few of these shots.
    BTW, I do have ambient audio on all cameras, if that helps me.
    Any ideas?
    TIA
    John Watts
    Premiere Pro Version 12.1.2 Build 69
    2017 iMac (Retina 5K 27 inch) 1TB SSD
    4GHZ Intel Core i7
    32GB 1867 MHz DDR3
    Graphics AMD Radeon R9 M395X 4096 MB
    macOS High Sierra Version 10.13.6
    Herb Sevush replied 7 years, 9 months ago 2 Members · 1 Reply
  • Herb Sevush
    December 11, 2018 at 12:00 am
    You can use the ambient audio if it is loud enough and well defined to create multicam clips with all your material. But you can’t re-sync a multicam source a second time. You can add shots manually, as you seem to be doing. The only thing you might try is creating another multicam clip with all sources using audio to sync, then copy only the xtra clips you are talking about and paste them into the original multicam timeline.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
