Activity Forums Apple Final Cut Pro Legacy Multicam Edit Issue– upon inserting the multiclip into timeline it becomes unrendered..
  • Multicam Edit Issue– upon inserting the multiclip into timeline it becomes unrendered..
    Posted by John Schlue on December 6, 2008 at 8:32 am
    I’m having an issue when trying to do a multicam edit. After I group my clips, designate my in-points, I try to insert my multiclip into the sequence and it automatically shows me the red unrendered bar both audio and video. I tried rendering and it rendered one of the files but when i set out to edit from clip to clip it stopped the process and showed up as unrendered again…
    Any suggestions?
    The files are qt files.
    John
    Heidi Laubscher replied 16 years ago 4 Members · 8 Replies
  • 8 Replies
  • Tom Wolsky
    December 6, 2008 at 9:50 am
    Please provide complete information of your system, your computer, amount of RAM, your drives, your camera/deck, how everything’s connected, the exact format of your media, frame resolution, frame rate and codec, and the exact format of your sequence settings, frame rate, frame resolution and codec. Also what versions of FCP, OS and QuickTime are you using.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • David Bogie
    December 6, 2008 at 4:23 pm
    Welcome to the family of frustrated multicam newbies.
    Most of the issues with multicam are simple user errors. The red render bar indicates your clips do not match your sequence settings. You have not provided enough information for either me or Tom to suggest anything else.
    Apple’s approach to multicam is clear as mud but, I must say, it works and it’s fun once you get it rolling. It’s just not as easy or intuitive as Apple wants you to believe.
    Suggest you start with shorter clips, say, 30 seconds max, and follow the setup very carefully, step by step. It’s all too easy to leave out one subtle step. And remember that the editing you do in the timeline is an effect. Once it renders, you cannot go back and easily re-edit the cutting until you unrender or delete the render media.
    bogiesan
  • John Schlue
    December 6, 2008 at 5:41 pm
    thanks guys. It was getting quite late and my brain was fried.
    I’m on a Imac g5 2ghz with 2gb of ram. HardD has about 150 gb of open space.
    FCP is 5.1, quicktime is 7.5.5. OS X 10.4.11
    The files I’m using are originally from flipvideo cams which come in as a avi. I’ve reformatted them into quicktime mpeg-4 files.
    –you’ll have to excuse my ignorance but I’ll try and provide the next info to the best of my knowledge. If there are simple ways to explain where I access any missing info via the program please tell me.
    Playback settings:
    RT: safe, vquality: low, frame rate: quarter.
    Memory and Cache
    App: 100% (1839 mb)
    Still: 100% (1689 mb)
    Thumbnail: disk 8192 k
    ram 1024 k
    Render Control
    Frame Rate: 100%
    Resolution: 100%
    I’m unclear of the codec.
    As mentioned above the clips were from flipvideo cams and have been formatted into quicktime mpeg-4 files.
    I hope this is a bit more thourough. I greatly apppreciate you taking the time to consider my problem. Again, if there is any info I am missing please inform me and I will to the best of my ability track it down.
    Thanks so much,
    John
  • John Schlue
    December 6, 2008 at 5:43 pm
    Playback settings:
    Memory and Cache
    App: 100% (1839 mb)
    ram 1024 k
    Render Control
    Frame Rate: 100%
    Resolution: 100%
    Thanks so much,
    John
  • Tom Wolsky
    December 6, 2008 at 6:42 pm
    MPEG-4 is not a format that is natively supported by FCP. It’s not a production format, I have no idea why someone would tell you to convert to that. You should convert to one of the formats FCP uses. Open your original media into the QT player and go to movie info and find out exactly what this material is an report back. You haven’t even told us if this is SD or HD.
    All the best,
    Tom
  • John Schlue
    December 7, 2008 at 5:00 pm
    Tom,
    here are the specs from the original footage:
    Format
    XviD (3ivx), 640 x 480, Millions
    Microsoft ADPCM, Mono, 44.100 kHz
    FPS: 30
    Data Rate: 3845.63 kbits/s
    normal size: 640 x 480 pixels
    actual size: same
    all standard def.
    Thanks again,
    I do appreciate the help!
    JSloo
  • David Bogie
    December 7, 2008 at 5:39 pm
    Those stupid little Flip cameras are gonna kill us round here the day after xmas.
    You can search the form for the camera model and its weird codec for hints on how to bring footage into FCP. I think most successful applications use MPEG Streamclip, a free format convertor.
    Microsoft ADPCM, Mono, 44.100 kHz< A few posts I've checked mention the "Mac version of 3ivx" is useless or even toxic. My workflow suggestion is to find the original files from the camera, hopefully they're on a PC and not a Macintosh. Run them through a convertor to create an interchangeable file such as plain old conventional DV. bogiesan
  • Heidi Laubscher
    August 22, 2010 at 11:58 am
    Not an expert, but I have found that sometimes when I manipulate the angle of one of my clips prior to making a multiclip, I get the “UNRENDERED” effect on all the unmanipulated angles. So I rather edit the whole thing and then manipulate each clip used from that angle afterwards, by copying the settings once and pasting its attributes into the other clips.
