Activity Forums Apple Final Cut Pro Legacy Multicam cutting causing crashes!!
  • Multicam cutting causing crashes!!
    Posted by Charles Jones on July 31, 2009 at 6:08 am
    I have a three camera shoot I am editing – two xdcam ex cameras – 1 pannie dvx100 – I transcoded (down ressed) the ex footage to SD by exporting from the timeline and creating DV NTSC – I did this because there was stop and starts on each of the cameras – so I exported each from the timeline as DV NTSC QT files with slugs in the void spots to keep each camera synchd. I created a multiclip – which is perfectly synched – will cutting – every 7 or 8 cuts when I select a clip to cut to, that image in the viewer goes haywire! and then it crashes fcp. I’m at FCP 6.0.6 and I’m cutting on MBP 2.16G Intel Core 2 Duo 4G RAM and running OS X 10.5.7.
    Please help!!!!!
    CJ,
    MOTU UltraLite, FCP2 Studio, MOTU DP5, EX1 and EX3
    G5, MBP
    Charles Jones replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
