Activity Forums Apple Final Cut Pro Legacy Multicam codec question
  • Multicam codec question
    Posted by Jana Birchum on July 21, 2009 at 4:59 pm
    I recently shot a multicam situation with two sony hd-11’s (ACHD codec, 1080i, 1920 x 1080, apple intermediate code, square aspect) and one panasonic p2 (dvcpro hd 1080p30 codec, 1280x 1080, hd aspect).
    can the panny footage be converted to something that works for mulitcam in final cut, or does it all need to be reformatted. and if so, what do you recommend for a format to use in final cut?
    i’m thinking i can reconnect to the original media once the edit is finalized. right?
    filmgrrrl
    Jana Birchum replied 17 years, 2 months ago 2 Members · 4 Replies
  • Steve Eisen
    July 21, 2009 at 5:43 pm
    convert everything to ProRes 422.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Jana Birchum
    July 21, 2009 at 6:11 pm
    and then when i’ve finalized the edit can i reconnect to the original footage and have it work ok?
    and thanks so much!
    filmgrrrl
  • Steve Eisen
    July 22, 2009 at 3:45 am
    When you are done, export a self-contained or Reference QuickTime Movie. In Compressor you can create a M2v and ac3 file for DVD. You can also create files for the internet.
    Steve Eisen
    Board of Directors
  • Jana Birchum
    July 23, 2009 at 3:01 pm
    ok, but the movie from the panny looks squashed in the compression you recommend. i’m thinking this won’t undo itself when i reconvert.
    wondering if i can’t just reconnect the media to the original files after finalizing the edit, then output.
    i can upload a sample of the conversion you recommend if you like.
    jana b.
