Activity › Forums › Creative Community Conversations › Multicam bug??
Multicam bug??
Posted by Tom Sefton on August 1, 2019 at 9:48 amSelect a piece of footage in your library. Right click and make new Multicam clip. Select custom format, and you cannot change the frame rate from 23.98. Why?
Co-owner at Pollen Studio
http://www.pollenstudio.co.ukTom Sefton replied 7 years, 1 month ago 2 Members · 3 Replies -
Ronny Courtens
August 1, 2019 at 11:06 am -
Tom Sefton
August 1, 2019 at 4:19 pmOk, try changing the format to custom first, then see if you can change the frame rate?? I can set it with a standard frame size but not a custom one
http://www.pollenstudio.co.uk -
Tom Sefton
August 1, 2019 at 8:59 pmThis shows our experiences with it.
Tried trashing preferences, and importing different footage. Seems to be the issue arises when the resolution for the Multicam is larger than 5K. Occurs with both red and prores footage.
http://www.pollenstudio.co.ukSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
