Activity Forums Apple Final Cut Pro Legacy multicam blues
  • Posted by Ron on October 17, 2006 at 10:06 am
    I ran into Problem the A camera have drop frame Timecode and all of B and C
    cameras have non drop timecode which is a problem for multicam because we are
    trying to sync by Timecode.
    too many clips to sync by IN or OUT
    any ideas
    thanks
    Ron
    Ron replied 19 years, 11 months ago 2 Members · 2 Replies
  • John Pale
    October 17, 2006 at 3:23 pm
    You can use an aux timecode to sync.
    For cameras B and C the aux timecode can be the same as the regular timecode. For camera A, convert the media start time to its correct value in non drop and enter it into the aux field.
    You can also simply change the actual timecode of the clip, but that would kill you if you had to re-capture.
  • Ron
    October 17, 2006 at 3:57 pm
    I did look into modifing the TC to non drop but sync is off.
    Ron
