Activity Forums Apple Final Cut Pro Multicam audio level is not the same on the final edit project – how to get 1:1 level throughout
  • Multicam audio level is not the same on the final edit project – how to get 1:1 level throughout
    Posted by Sam Lee on December 29, 2016 at 9:56 pm
    Is there any reduction in audio level from the multicam sequence to the final project? In other words, will it be a 1:1? So far I noticed it’s not 100% the same. Instead, ther is a small reduction in the final level.
    Noah Kadner replied 9 years, 8 months ago 2 Members · 3 Replies
  • Noah Kadner
    December 29, 2016 at 11:41 pm
    This can be due to a variety of factors- for example you may have multiple angles with their audio active in the Angle Editor whereas your final timeline only has a single audio angle active at a time. More info needed.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Sam Lee
    December 30, 2016 at 1:06 am
    My angle editor has 3 angles: A cam, B cam, and sound recorder. In the angle editor, I only chose the sound recorder as the active audio angle. If I do this, then only the sound recorder angle gets carried over to the final project right?
    If I have clicked on A angle and sound recorder angles (via the purple speaker icons), will both of these angles get carried over to the final project too?
  • Noah Kadner
    December 30, 2016 at 6:10 am
    You can only have one audio angle active in a project timeline at a time. Control click on a multicam clip to see which audio angle is currently active.
    Noah
