Activity Forums Apple Final Cut Pro Legacy multicam as one sequence
  • John Pale
    October 8, 2010 at 4:10 am
    FCP has multicam, but you prepare your material in an entirely different manner. You do not make multiple sequences like in Premiere…you create multiclips before cutting it into a single sequence. When played back in the sequence timeline, the multiclip shows all angles and you can cut between them on the fly…finetuning later.
    Is that what you are asking?
