Activity Forums Apple Final Cut Pro Legacy Multicam angle viewing
  • Multicam angle viewing
    Posted by Jeffrey Lonigro on May 14, 2010 at 5:47 pm
    I have a multicam clip generated from pluraeyes. I have sync set to open. When I hit play only the active track is showing in the viewer. When I stop playback the viewer shows all camera angles. Sometimes it works other times not. Any clues?
    Shane Ross replied 16 years, 4 months ago 3 Members · 2 Replies
  • Michael Sacci
    May 14, 2010 at 8:30 pm
    99% of the time the multicam clip has been rendered in the timeline, make sure you turn off Auto-Render. Fastest way to break this is to turn the track off and on and all should be good.
  • Shane Ross
    May 15, 2010 at 12:27 am
    IN the RT menu on the timeline, you must check the option, MULTICLIP PLAYBACK.
    Shane
