Activity › Forums › Apple Final Cut Pro › Multicam angle viewer
  • Multicam angle viewer
    Posted by James Ewart on May 29, 2014 at 11:32 am
    Bit of a niggle issue in multi cam.
    Every now and then even with a two camera multi cam project the little windows do not display the full frame that is displayed in the “canvas” (sorry what is the main biker called again?)
    Workaround is to change view to 4 angles until same thing happens and then switch back to 2 angles. Etc. Etc.
    As you can imagine it is mildly tedious.
    I’ve tried trashing prefs … didn’t make any difference.
    I think I had this issue back with older version and I am working in proxy so not quite sure what the problem is. Working on quite an old iMac could be the issue? No other performance issues though.
    James Ewart replied 12 years, 3 months ago 4 Members · 16 Replies
  • 16 Replies
  • Jeremy Garchow
    May 29, 2014 at 1:03 pm
    What do they display?
  • James Ewart
    May 29, 2014 at 3:02 pm
    Cropped images. Intermittent “buggy” problem. Sometimes it doesn’t happen. Then sometimes it happens all the time.
  • Jeremy Garchow
    May 29, 2014 at 3:14 pm
    Can you post a grab when it does happen?
  • Loren Risker
    May 29, 2014 at 4:29 pm
    I’ve had this happen through some combination of the following:
    Mixed resolution source files
    Image scaling set to “none”
    Switching the resolution of the multicam after it’s made
    Are you mixing resolutions?
    OutOfFocus.TV – Original series, music videos, mini-docs.
  • James Ewart
    May 29, 2014 at 5:35 pm
    Sure. It hasn’t happened today. Yesterday all the time! Thanks.
  • James Ewart
    May 29, 2014 at 5:39 pm
    No I’m not mixing resolutions but I am switching to View Proxy having created the multicam clip and dropped it into a project. I have created proxy files on Import. Hmmm. Wonder of thats it? Trouble is it does not much like the original files and I have not created Optimised Media on import but I have inadvertently been creating Optimised Media by leaving box checked in prefs (thanks Jeremy)
  • James Ewart
    May 29, 2014 at 5:56 pm
    When you say “Image Scaling” what do you mean exactly please? I usually have mine set to “Fit”in the canvas/viewer window…no option for none. Do you mean something else I wonder?
    Many thanks
    James
  • Loren Risker
    May 29, 2014 at 6:03 pm
    Sorry, I meant to say Spatial Conform. But if you aren’t mixing resolutions then sounds like you’re having a different problem.
  • James Ewart
    May 29, 2014 at 6:10 pm
  • Jeremy Garchow
    May 29, 2014 at 7:11 pm
    It looks to me like you have the clip scaled up in the angle editor, and then scaled back down in the timeline. Or something like that.
    Jeremy
