Activity Forums Adobe Premiere Pro Multicam and Mixed framerate footage CS5
  • Multicam and Mixed framerate footage CS5
    Posted by David Oulashian on April 6, 2016 at 5:12 pm
    Hello all,
    Long time Avid Editor cutting multicam in Premiere Pro CS5 (I know, I know).
    2 cams are 23.976 fps, 1 cam is 25 fps. Sequence is setup as 23.976 fps.
    The 25fps cam always shows a red render bar above those clips. Sometimes it plays fine, sometimes it hangs. Should I transcode my 25fps footage to 23.976? If I do will that mess up all the syncing I’ve done already? Any advice would be greatly appreciated.
    FWIW I’m on a MAcBook Pro 2.2ghz i7 with 16 Gigs of RAM and footage on a 1 TB Fantom Drive/Firewire800.
    Much thanks,
    David
    David Oulashian
    David Oulashian replied 10 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
