Activity Forums Apple Final Cut Pro Multicam, added an audiotrack in angle editor, want to change all clips to new audio track.
  • Multicam, added an audiotrack in angle editor, want to change all clips to new audio track.
    Posted by Jonas Bengtsson on April 17, 2013 at 11:06 am
    Multicam, added an audiotrack with mixed audio in angle editor.
    Now I want to change all clips in the multitrack edit to the new mixt audio track.
    Tried to select al multiclip in project timeline and right click, Activ Audio Angle> Track 1-4, but they are all greyed out.
    Jonas Bengtsson replied 13 years, 5 months ago 1 Member · 1 Reply
  • Jonas Bengtsson
    April 17, 2013 at 12:20 pm
    Founded it in the FCPX Help
    Switch angles in the Inspector
    Switching angles in the Inspector allows you to switch angles for multiple selected multicam clips at once.
    Select one or more multicam clips that you want to switch.
    Open the Info inspector.
    In the Info inspector, do one of the following:
    To switch the video angle: In the Active Video Angle pop-up menu, choose the angle you want to switch to.
    To switch the audio angle: In the Active Audio Angle pop-up menu, choose the angle you want to switch to.
