Activity Forums Apple Final Cut Pro Multicam
  • Posted by James Ewart on September 6, 2014 at 7:20 am
    … had a very late night working and got myself a bit confused.
    I’ve got nine angles on my multicam clip. Not all absolute perfect sync but I synced them all up now in my project through double clicking and opening the angle editor.
    These corrections appear to have also taken affect in the original multicam clip.
    That’s right isn’t it? If I make changes in angle editor via the project itself these changes go back to the original “master” multicam clip?
    http://www.jamesewart.co.uk
    Robin S. kurz replied 12 years ago 5 Members · 7 Replies
  • 7 Replies
  • Bret Williams
    September 6, 2014 at 12:28 pm
    Yes that is correct. Just like a compound clip.
  • James Ewart
    September 6, 2014 at 12:35 pm
    Got muddled because at one time compound clips did not behave like that I don’t think?
  • Craig Alan
    September 6, 2014 at 1:45 pm
    Depends if u create it as a new master.
    Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
  • James Ewart
    September 6, 2014 at 4:25 pm
    “Depends if u create it as a new master.”
    Not with you there Craig could you explain.
    Plus struggling to get the roles out as not showing in Timeline Index only when I expand audio components.
    Original files were .MP4.
    Best
    James
  • Jeff Kirkland
    September 6, 2014 at 10:43 pm
    You are thinking of compound clip behaviour prior to 10.0.6. Since then changes to the parent ripple down to the child clips on the timeline. The same goes for multicam clips – the angle editor opens the parent and any changes ripple down to instances you have on your timeline.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Craig Alan
    September 7, 2014 at 12:38 am
    https://www.larryjordan.biz/fcpx-compound-clip/
    UPDATE – Aug. 2013
    This behavior changed with the 10.0.6 FCP X update. Now, if you modify a compound clip in the Timeline, it modifies all occurrences of that compound clip in the Project. The way to change one compound clip without changing all the others is to select the clip in the Timeline, and choose Clip > Reference New Parent Clip.
    This duplicates the clip in the Event Browser. Rename and use the new duplicate clip. You can make as many changes to the duplicate clip as you want, without having those changes ripple back into the original clip.
  • Robin S. kurz
    September 7, 2014 at 11:50 am
    Simply following the path at the top left of the angle editor (or even in the timeline window of a compound clip) will tell you that you are editing the (master) clip in the event and not that in the timeline.
