Activity Forums VEGAS Pro MultiCam
  • MultiCam
    Posted by Joao Carlos schwalbach on October 8, 2014 at 6:21 am
    I have this project to edit. Live concert with 4 cams (3 x 5Ds and 1 go pro).
    What is the best/friendly way to edit multi cam in vagas12?
    If I use the multicam tool, how do I undo/finetune edits? And I don’t like the fact that once you choose the multi cam tool you can’t go back to single track view.
    A long time ago I used to used Ultimate2 bt vasst. Is that still an option?
    What is the best way?
    Thank you
    Nigel O’neill replied 11 years, 11 months ago 4 Members · 7 Replies
  • 7 Replies
  • Bob Peterson
    October 8, 2014 at 3:07 pm
    I always duplicate tracks that are going to be in the multi-cam track. I use the duplicates to create that track so that the original tracks are not lost. I use multi-cam to find the locations where I switch to a different camera. I then use composite envelopes on the original tracks to implement the camera selections that I made in multi-cam. It’s a little more work, but it preserves maximum flexibility for later editing changes to the project.
  • Joao Carlos schwalbach
    October 8, 2014 at 4:05 pm
    Thanks Bob. That is a good workaround.
    But sony could perfect this. The multi cam talk could me made in a way that preserves the original tracks and mutes some clips while showing others. Or in some other way. For me it doesn’t make sense to loose the original tracks….
  • Aleksey Tarasov
    October 8, 2014 at 4:18 pm
    > “And I don’t like the fact that once you choose the multi cam tool you can’t go back to single track view.”
    You can expand multicamera track to multiple tracks.
    October 8, 2014 at 6:50 pm
    Aleksey, How do you do that?
    thanks
    joni
  • Aleksey Tarasov
    October 8, 2014 at 7:02 pm
    menu item: Tools > Multicamera > Expand to Multiple Tracks
    October 8, 2014 at 7:31 pm
    thank you
  • Nigel O’neill
    October 9, 2014 at 10:40 am
    You could look into Vaast Ultimate S Pro (which is what I use)
    https://store.vasst.com/store/vasst-software/ultimate-s-pro.aspx
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
