Activity Forums Blackmagic Design Multibridge/HDLink with Panasonic 50″ Plasma
  • Multibridge/HDLink with Panasonic 50″ Plasma
    Posted by Chris Borjis on November 20, 2006 at 5:27 pm
    I’m getting ready to purchase the new Panasonic HD Plasma
    monitor model # TH-50PH9UK.
    How well does the multibridge extreme map to the pixels on the panasonic?
    I’m using a dell 24″ lcd right now.
    We do mostly 720P work, and this monitor is slightly higher than 720P.
    Does it map it pixel for pixel through HDMI?
    Aaron Neitz replied 19 years, 9 months ago 4 Members · 6 Replies
  • Bob Zelin
    November 20, 2006 at 11:41 pm
    The Panasonic Plamsa will look BEAUTIFUL – this is the montior used by Blackmagic at the NAB show (it was used by everyone else also).
    this monitor can easily display 1366×768, which is what is required for 720p work.
    Bob Zelin
  • Chris Borjis
    November 21, 2006 at 12:33 am
    Thanks for the reply Bob.
    Does it map it perfectly for HDMI as well as component analog?
    (it only comes with component analog built in as i understand it)
  • Bob Zelin
    November 21, 2006 at 4:14 am
    never tried ANYTHING with HDMI, so I can’t answer you.
    Bob Zelin
  • Margus Voll
    November 22, 2006 at 12:05 pm
    Hi.
    How does SD look on that panny ?
    Margus
    https://iconstudios.eu
  • Bob Zelin
    November 22, 2006 at 1:49 pm
    SD looks ok, but the best looking LCD/Plasma for STANDARD DEF is the Panasonic 26″ BT-LH2600W LCD monitor, which was designed specifically for applications like this. But I realize that you want a 50″ monitor – and you will be happy with the TH50.
    Bob Zelin
  • Aaron Neitz
    November 28, 2006 at 6:40 pm
    On another note: we’re idly talking about getting a big plasma for 1080p display over the HDlink with HDMI. Anyone delved into that?
