Activity › Forums › Blackmagic Design › Multibridge studio + Terranex mini
  • Multibridge studio + Terranex mini
    Posted by Chris Paul on December 1, 2005 at 5:15 pm
    I really like the way multibridge studio should be able to connect to a varitey of sources. The only thing it seems to lack is the reatime up convert from SD to HD that the Kona2 has. I see that Terranex has a dandy little SD to HD up converter but it only has sdi inputs. Is iat possible to send analog component from a beta deck through the multibridge to make it SDI, then through the Terenex and finally back through the SDI of the Multibridge and into the computer all in one go? In other words, can the Multibridge process 2 tasks at once?
    Chris Paul
    POV
    Luke Maslen replied 20 years, 10 months ago 2 Members · 1 Reply
  • Luke Maslen
    December 2, 2005 at 5:33 am
    Hi Chris,
    While I believe that will be possible, I won’t be in a position to confirm that until the product is closer to shipping.
    Regards,
    Luke Maslen
    Blackmagic Design
