Activity Forums Blackmagic Design Multibridge SD in PCI-Express x1
  • Multibridge SD in PCI-Express x1
    Posted by Markh on May 17, 2005 at 1:22 am
    The Multibridge PCI-Express x1 (little card) typically has more bandwidth in the PCI-E slot than regular 32-bit PCI slots, correct? Hence, putting the Multibridge on a PCI-E x1 slot and using a 4x SATA RAID stripe on the motherboard should be ok for SD playback. Would be good to know.
    -m
    Markh replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
