Activity › Forums › Blackmagic Design › Multibridge Red Blinking Light
  • Multibridge Red Blinking Light
    Posted by Afc Dmc on July 24, 2007 at 1:13 pm
    Hi we just got a Multibridge Pro last week and we installed successfully we even capture via analog component and view it on a crt video monitor! but yesterday I noticed a RED Blinking light in the Multibridge Pro!!! and the computer didn’t recognize the card!!! I power it down, change it to another outlet and still the RED Blinking light!!!! this happened even when the computer is off, and with out any cables connected to the Break out Box!!! It just Blinks and I hear a faint blinking sound!!! Dos this is a defective Unit?? I was able to used it just one Day!!!!! The Multibridge was connected to a UPC battery, with the computer. Please Help me I need this system running!!!
    afc
    Kristian Lam replied 19 years, 2 months ago 3 Members · 4 Replies
  • Deleted User
    July 24, 2007 at 1:34 pm
    Hello,
    In convertor mode when the Machine is connected to the computer, using USb you can control te red light and make it flash and/or dim down.
    Also the battery supply you were running could of possbily damaged the unit somehow, is it a high pitched sound, fan spinning inside the unit ?
    Leo
  • Afc Dmc
    July 24, 2007 at 1:46 pm
    Thanks fot the response!!! I am not using it a convertor mode. I am using it as a Capture, Playback. The noise is like a clicking sound!! and is in sync with the red blinking light!!! and I can not hear any fan noise. It just blink whether is connected to the computer or alone without any cables plug in to it!!! Can I use another power supply to verify if it is damage?
  • Deleted User
    July 24, 2007 at 8:30 pm
    Hello,
    I am not to sure what the clciking could indicate, best to get it checked by your dealer or BlackMagic. You would have to test it with the power supply with the unit, as you would void the warranty if you use another power supply as it may damage the unit beyond repair.
    Leo
  • Kristian Lam
    July 27, 2007 at 7:54 am
    It’s most likely faulty and should be replaced if you have not contacted your reseller yet.
    regards
    Kristian Lam
    Blackmagic Design
