Activity Forums Blackmagic Design Multibridge Question
  • Multibridge Question
    Posted by Aaron Cadieux on September 17, 2009 at 2:43 am
    So I’m finding that it’s impossible to use the Multibridge Pro as BOTH a stand-alone converter AND in conjunction with the Decklink software. With the Decklink software installed, the Multibridge utility is rendered useless (greyed out), and with the Multibridge software installed, the Decklink utility is rendered useless (greyed out). The Multibridge will update its firmware, but will only update it for one application or the other. I can’t use both the Multibridge software and Decklink software on the same computer. Why would this be designed this way? It’s dumb.
    Aaron Cadieux replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
